Buy the part yourself with a BMW CCA discount and then bend over and kiss your .. . Ehh, well, then you get to pay for labor. Tearing apart your entire dashboard/firewall. It's exciting. The mechanic will love it.
I have a '95 530i with stock R-134a AC. This is my 4th Summer and when I went to crank up the AC for relief, I was rewarded with a blast of warm air. The compressor runs which I imagined meant that I had some refridgerent otherwise the cut-off switch would have disabled the clutch so I bought a recharge kit hoping for a quick fix. Step one was to measure the pressure on the low side which indicated 80 psi which, according to the guide on the kit means, game over - go to a mechanic. Searching past articles on the board it seems that AC repair is mondo expensive. Does anyone have any suggestions?
when you tested the low side?
Did you also check the high side?
I had purchased a kit which only had a low side attachment. But yes, I followed the directions: The A/C was on, the fan was on full, I checked the pressure after running with the gauge connected after 3 minutes or so.Originally Posted by Blitzkrieg Bob
have someone test the high side, then you can tell which is failing.
Expansion valve or compressor
