What the condition of the belt? how's the tension?
At 160 Kmi the AC compressor on my 1995 525 developed a noise (when the AC is activated), and now the compressor will seize as the engine RPM is increased (the compressor stops rotating and the belt slips). I hope that the compressor has not been damaged to the point of "Black Death" http://www.ackits.com/index.cfm?fuse...=black%20death
Planning to replace the compressor/clutch and the accumulator/drier. The coolent appears to be r134, so other than having an AC shop recover the Freon, and replacing all Orings. I wonder if there are other suggestions from board members.
Some questions:
1. Do the replacement compressors come with the compressor oil or does it need to be ordered separately?
2. Is it necessary to put some refrigerant oil in the accumulator/drier before evacauting and recharging the system.
Michael Feeney
91 and 95 525i
BMW parts professional
Previous rides:
BMW
E12 M535i (go the dogleg!)
E28 M535i (MMM M88!)
E34 535i M
MAZDA:
RX7 S-IV T04 (440 hp ATW)
RX7 S-I 13b bridge port
RX4 13b peripheral port
If you need a new AC compressor, or another one rather, I have one. I think its the older ac gas unit, but maybe you can use it.
Thanks for the advice. Turns out that the belt tensioner is not maintaining sufficient tension and the belt was slipping. The belt appears to be in good shape but I'll most likely replace the tensioner and belt.
Michael Feeney
91 and 95 525i
