Results 1 to 10 of 14
Thread: next upgrade
    Chapel Hill, NC
    Default next upgrade
    I'm thinking about 17" wheels for my next purchase. For those of you that have the RONDELL #58 are you satisfied with them? What size would work best 17x8, 17x8.5, 17x10? Is the offset correct or will I need spacers?
    Chip
    '92 535i 5sp
    EAT chip, Sachs kit, RRT sport control and upper thrust arms, SS brakelines, Camber plates, Subframe inserts, 3.64 Diff, M5 (3.6L) calipers.
    '87 325iS
    I might be up for flames,I'd personally go 18's, i don't understand why people don't go 18's aswell. It fits the car so much more to shape. I've got 18's and they look perfect aligned with the body and guards and not too big.
    freezin ass cold WI formerly freezin ass cold MN
    Chip, I've got 17x8.5 front and 17x10 rear. I got them from wheel exchange and they needed nothing.
    Here's a link that might work to some pics
    http://f1.pg.photos.yahoo.com/ph/sco....net/my_photos
    95 540 six speed, Rondell 58 wheels, nothin else special
    79 911 SC - pea soup green
    Philippines
    I'm running 18s...will post pics once my car comes out of the shop
    Canada, ON
    18" rims are heavier, more frigile and the tires are more expensive.
    Looks better... but not worth the price increase in my case.
    Philippines
    Hey Bruno! Question regarding wheels, offset and spacers.... the E34 I bought came with 18" rims, and (to the best of my research and tracking) 15mm offset. What would be the best spacer to use for this? I read your site, and was a bit confused... do I use a 5mm spacer? Or a 10mm hubcentric? What do I tell the guys at the wheel shop? I'm having doubts that the original owner was out for performance, so I just wanna have it checked and in case it isn't set right...I'd like to know what to have done. Thanks again for all the help... you're site has been sooooooooooooo helpful!!!!
    NJ
    Default If they're really 15mm offset, you don't want a spacer
    The 15mm offset will already put the tires near your fenders. Spacers will only push them further out, and will almost definitely cause rubbing. Find out for certain what width and offset the wheels are, and what size tires are mounted before doing anything about spacers.
    Drew Zacharda
    6-speed Touring with 17x8.5 15mm offset wheels and 245/45/17 tires
    Quote Originally Posted by jplacson
    Drew Z
    Formerly 540iT/6, now . . . 3, 5, 7
    Philippines
    Ok, thanks! Hmmm... I see you have 15mm offset wheels too! :P How does this affect handling? So far, I've been using 225/45 R18 tires on them. They do rub at full lock, so I just back off about half a turn... I lose turning radius. I figured something was wrong with the previous owner's setup... I just want to know if there's anything I can do about it without changing wheels (I can't exactly afford a new set)
    Thanks again!
    **PS... my wheels are BMW 745 Replica wheels 18" ... the wheels of this type that I've found online all have 20mm offset, but the shop that sold a set just like mine (I don't know where the previous owner bought the set that's on my car) say they are 15mm... Is there anyway for me to check the offset myself?
    Denver, CO
    Default I just put 17" t-stars on (m).
    I also have a 1992 535i 5 speed with the Sachs Kit and an EAT chip. I considered the Rondell 58 but found a good deal on a set of t-stars (17x8) with Yoko AVS db's. I was concerned about ride quality issues getting worse with the 17"s over the 15"s, as it seemed pretty harsh already. Everything is actually better with the 17"s re: ride, response, tracking, noise, etc.
    Don't know about staggering but I think you'll be pleased with 17"s coupled with your setup.
    Just fyi. Hth.
    Armpit, USA
    Default What size tires are you running?
    Quote Originally Posted by scott540
    1995 530i 5-Speed
  1. air-con upgrade...
    Last Post: 02-04-2008, 06:24 PM
  2. Upgrade Help
    By 92_e32_525i in forum 5 Series BMW
    Last Post: 12-12-2006, 06:56 AM
  3. AFM Upgrade, help please
    By Jose in forum 5 Series BMW
    Last Post: 02-16-2005, 01:17 AM
  4. Upgrade
    By ccwest in forum 5 Series BMW
    Last Post: 01-11-2005, 10:49 PM
