Originally Posted by
Reckless_Kelly
Unless you know what you're doing, you will most likely lose HP with that thing, and if you knew what you were doing, you would have already ordered it. There is not much to gain from simply adjusting fuel pressure (definitely not the 15% that the seller guarantees). It would be good to have adjustable pressure if you were moving considerably more air (turbo, supercharger, larger displacement, etc), but with a stock motor, the fuel injectors are ideally matched to the motor. Save your money and your motor, don't buy it.
Thanks for the info.
1995 540i Manual build 1/95
