My 520i 1990 M20 is cutting off around 5000 RPM and the needle flickers and then the RPM picks back and this usually occurs on 2nd 3rd till 5th gear. MAybe bacoz on the first gear I simply zoom through the RPM range but when I start smoothing the RPM range on 1st gear it does cut-off. This thing caused my muffler to explode last week and I had it replaced and then the issue still persists.
1) I changed the engine control module, the crank sensor and the ignition coil and it never changed.
2) What do I need to do? Can I put the car on the diagnostics computer and will it show for such a late model any previous faults ???
What do you guys suggest I do next????
