Results 1 to 7 of 7
Thread: m60 engine overheated
    May 2006
    yorkshire
    Default m60 engine overheated
    Hi, my 3.0 m60 overheated today, It rapidly overheated while i was looking for a place to park, by the time I'd stopped it was halfway through the red. i popped the bonnet and the radiator top hose had blown off the radiator and snapped the plastic connection off. there was enough pipe left for my to put the hose back on, I put in as much water as was in the car (about 6 litres) started her up and the temp went to dead centre. All i can think of is that the rad top hose conection must have been cracked, finally broken and started leaking, the car gave an over heating warning, then as soon as i stopped it gave a low coolant warning. any help would be greatly appeciated. thanks
    USA
    sounds like you need a new rad. quick!
    sounds like you need a new radiator too. There is a guy here that has one
    http://www.bimmer.info/forum/showthread.php?t=23436
    and also check out radiators.com
    and www.rockauto.com
    good luck!
    Red 525i (restoration in progress)
    89 Corolla All-Trac Wagon (parts getter, daily driver)
    May 2006
    yorkshire
    thanks for the help.gonna try fitting an insert in the broken fitting and araldite the parts back on. if that doesnt work its gonna be a new rad. thanks
    BMAparts.com will match prices you get from other places, I got mine the next day with no shipping charges.
    Maryland, Virginia, D.C.
    That is a pisser..
    Hockinson, Washington
    Ö.o
  1. Overheated & Confused
    By cruisin5 in forum 5 Series BMW
    Last Post: 04-17-2006, 05:28 PM
  2. Overheated Transmision ?
    By Strap in forum 5 Series BMW
    Last Post: 11-21-2005, 06:56 AM
  3. Damn!!! Car overheated. HELP
    By InfernoM3 in forum 5 Series BMW
    Last Post: 11-02-2005, 11:28 PM
  4. overheated
    By Ali in forum 5 Series BMW
    Last Post: 09-27-2005, 01:15 PM
  5. Overheated!
    By forestnut in forum 5 Series BMW
    Last Post: 09-02-2005, 04:51 AM
