Results 1 to 4 of 4
Thread: Trailer Hitch Source
    Default Trailer Hitch Source
    Guys,
    I've been looking for a nice trailer hitch for the e39 540iT. I found this source:
    http://www.hmsmotorsport.com/store/e...n-hitches#1952
    I noticed they have an e34 version for under $200.
    Anyway, has anybody seen this product? If so please comment on it.
    Also, I figured I'd just tap the brake wires and make a little harness with some bullet connectors, but is there a better way?
    I don't want to shell out for the Westfalia one.
    -tim
    o/______\o
    (Oo=00=oO)
    Elm Grove Farm, NC
    Da'lan makes good quality hitches for Euro cars (that's what HMS is selling in the link you provided. I don't have experience with that exact hitch, but I've seen some of their other hitches and they are very well-built.
    As for the wiring, don't make it harder than it needs to be. Use a standard "taillight converter" to tap into the taillight wiring, use those little scotch-lok connectors so you won't have to cut/splice the wiring. Then just get a flat 4 trailer connector for the car and you're there!!! (assuming the trailer you're hauling has a flat 4 connector...if not, just get whatever matches.)
    Trailer wiring supplies like this are readily available- WalMart or your local chain auto parts place should have what you need.
    Bret.
    Tim,
    I'd be carefull of the trailer lights hook-up. You know how touchy the OBCs and check controls are. The wrong wattage on a bulb is enough to trigger a fault indication. Looking into BMW approved may save some headaches.
    Dec 2005
    Independence Oregon USA - pop. 6000
    Just went to the DaLan website and then called HMS to double check. Note that although it looks like a reciever type hitch the E34 model (at least) is a fixed hitch. Shin biter alert. DaLan is a good product, but be aware of what you are getting before ordering. No problems here with the trailer converter wiring Bret mentions. Rarely get a fault indication, though it does happen.
    Tom
  1. Westfalia Trailer hitch - installation instructions
    Last Post: 07-28-2009, 09:10 PM
  2. need a trailer/tow hitch?
    Last Post: 04-09-2009, 12:53 AM
  3. trailer hitch part number?
    Last Post: 03-15-2008, 09:14 AM
  4. Building a trailer hitch for 525iT
    By calmloki in forum 5 Series BMW
    Last Post: 05-26-2006, 12:48 AM
