With the temp set to cool, before starting the engine tap the valve...then after (running cool) then again whilst its hot. Maybe it will close for you- are you feeling lucky? ~! NickOriginally Posted by BillionPa
its summer and hot and im burning up!!!![]()
not enough time to research gotta go to work but first i sleep night!
My e28 M535i used to blow hot air all the time, it was nice sauna feeling going down the highway doing 200km/h.
But otherwise it was actually not that horrible even during the summer.
telling how can take the heater hoses to bypass the core in the passenger compartment.......that may get you through until can open and repair the valve, which a photo rich document was linked to by shogun (search again for user shogun) describing how to remove and clean the valves.
Rob.
The easiest fix (for now) is to take the valve apart and then put it back together with the valves locked in the closed position. I did this once using a wooden match stick to hold the valve shut.
Order a new valve from BMA before winter.
Mark Hall
'95 525iA EAT chipped (just one now)
'98 528iA
strange thing is, it seems to not blow hot air with the fan in position 1, but burning hot in all the other positions. i think im gonna try to fix it... and use up some more coolant in the process.
hmm, to help, is it safe to disconnect the power from the aux water pump?
Yep, it only helps to keep the heatflow through the heater core constant and therefore help regulate cabin temperature. If you bypass, you should do this. I removed my valve and pump assy altogether once. just connect the two hoses coming from the motor together with a pipe and your're done.Originally Posted by BillionPa
Nick
bmwe34.net had the solution... loosen all those torx screws and whack it with hammer to loosen that stuck valve. You do this when car is cold, engine off, and key on.... turn hot... whack a little bit... turn cold... whack a bit... repeat a couple of times... and tighten up the torx... done.
