Results 1 to 9 of 9
Thread: Question
    Aug 2005
    Default Question
    A pic borrowed from Jon K's post. What is the item that I indicated with an arrow? In an another car I also saw a box on the same location but on the left side.
    VIN: GG45422
    Hockinson, Washington
    Quote Originally Posted by t_marat
    airbag thingy.
    yep, thats the thing to avoid with water and bumping when the cars ignition is on.
    airbag thingy.
    Maryland
    is there a fuse in that casing?
    Aug 2005
    a kind of shock sensor? isn't the shock sensor (airbag sensor) located under the rear passenger seat?
    VIN: GG45422
    Default No, there's not a fuse ,its an
    impact sensor as shown here... the metal roller on impact rolls forward and makes or breaks the contact shown here which triggers the airbag .. short version anyway.
    Quote Originally Posted by Evan
    Maryland
    Are we talking about the box or the casing with a wire coming out of each end?
    Default The box is the sensor itself, the casing with the wire
    coming out of each end is strictly the connector for it.
    Nov 2004
    its not "kind of" a shock sensor...it IS a crash sensor. If you run into something or something runs into you...and as Bill R described...there is enough force to cause the roller to move forward and make contact...or if it breaks...it will deploy the airbag. That's why there is one on each side of the engine bay.
    Q
    95 525iT / 97 740iL
  1. Replies: 1
    Last Post: 11-06-2009, 07:35 PM
  2. Fuel filter question and bumper question
    By 1995 525i in forum 5 Series BMW
    Last Post: 08-26-2004, 08:22 AM
