Takes a while, you'll get a head ache, but it works
How is wheel offset calculated? Is it...
(Inside Edge to Hub - Outside Edge to Hub) / 2
or
Current
2008 M5 6 Spd
2000 Z3 2.8 5 Spd MSport
2012 X5 35d Sport
1995 540i 6 Spd
1992 535i 5 Spd
Former
1995 530iA
1986 635CSI 5 Spd
2011 X3 2.8 MSport
I just failed my calc test![]()
www.KaRealtySF.com
Seriously, define the variables plz.
Originally Posted by Blitzkrieg Bob
Current
2008 M5 6 Spd
2012 X5 35d Sport
1995 540i 6 Spd
1992 535i 5 Spd
Former
1995 530iA
1986 635CSI 5 Spd
2011 X3 2.8 MSport
But first you need to know what the offset is, right?
Offset is the distance from the centerline of the rim to the wheel mounting surface. So divide the rim width in half, and subtract that from the distance from the mounting surface to the inner edge of the rim. I get that distance by laying a straight edge across the back side of the rim and measuring down to the mounting surface.
I think your agreeing w/ my proposed calc 1.
My question was directed at calculating the offset of any given rim by hand, not comparing 2. I was curious if the offset of my new rims was correct regardless of markings.
It says 20, but my measurements were 135mm inside, 100mm outside, so 35mm by 2 is 17.5mm....
Originally Posted by Karl
Current
2008 M5 6 Spd
2012 X5 35d Sport
1995 540i 6 Spd
1992 535i 5 Spd
Former
1995 530iA
1986 635CSI 5 Spd
2011 X3 2.8 MSport
Look at the diagram from the page and taking you measurements as..
total rim with= 235CM
Mid line @ 117.5
117.5 - 135 = 17.5 or 117.5-100 (this depends on if you north or south of the equator)
I guess 2.5mm is wiggle room.
pictures speak lots of words ... see this ...
http://www.bimmer.info/forum/showthread.php?t=22893
'90 535iSE Auto (AE+EAT) 123k miles
'86 F288 69k miles
'06('89)- PGE 2.0DOHC Turbo
'03 A160LE 19k miles
1914 Stellite E2A (no odometer!)
(+ others I daren't mention here)
www.pyghtle.com
