Results 1 to 3 of 3
Thread: purge valve---charcoal canister
    Default purge valve---charcoal canister
    so, my "purge valve" is clogged/busted.
    what iv learned on the purge valve:
    [*]holds exhaust gasses[*]waits for right engine condition. ie. cruising on the highway, accelerating a bit. than releases gasses to be burned off[*]probably kills HP[*]mines broke, so it hold gasses, than releases them all at once causing engine stutter.[*]connected to radiator/charcoal canister
    do i need this? or is it good to have?
    do i get it removed or do it myself?
    do i need to be "legal" as some would call it?
    thanks all
    ~farley
    USA
    its not connected to the radiator
    it is not needed for operation of the car
    it can be removed
    it DOES improve startup by enriching the air intake vapors
    it DOES present serious problems of vacuum leakage with age (sounds like what you have is a large vacuum leak)
    the tube connected to the valve goes directly to the throttle body, the other side of the valve is connected to the canister, and the other tube from the canister goes to the gas tank.
    the canister also has a drain cap on the end, so if the valve is stuck, you have a bad intake leak. you can remove the vacuum hose end from the valve and plug it up. that should solve your problem in the immediate while you determine the course of action, which is:
    A: ditch the whole thing.
    B: get new valve and canister and fix it.
    whoa, thank you very much. i think il get on that.
  1. MPG and charcoal canister
    By Rustam in forum 5 Series BMW
    Last Post: 01-30-2011, 03:44 PM
  2. Evap purge valve
    By wjbell in forum 5 Series BMW
    Last Post: 04-11-2007, 11:40 PM
  3. Removing charcoal canister...
    Last Post: 10-29-2006, 01:48 AM
  4. purge valve
    By krazy00kanadian in forum 5 Series BMW
    Last Post: 06-12-2006, 11:49 AM
  5. replaced charcoal canister 1995 525i
    Last Post: 07-08-2005, 06:04 PM
