Results 1 to 10 of 12
Thread: Oil Pressure Sensor and Won't Start
    Jun 2006
    Wisconsin
    Default Oil Pressure Sensor and Won't Start
    Hi All ~
    I'm having an issue with my 1990 525i/M20 which just decided to pop-up yesterday morning. The engine cranks over fine but doesn't want to start, this is accompanied by the Oil Press Sensor warning appearing in the display. After about 8-10 10 second crankings the engine will start and run perfectly. I've ordered a new oil pressure switch (12 61 1 710 509, cheap and easy to replace) but would really appreciate any suggestions as I have a gut feeling it's not going to be that simple. Thanks!!
    I believe the fuel pump will shut down under zero oil pressure conditions. But it should run for a short period during startup. If you are convinced there is indeed oil pressure try using some ether or carb cleaner etc. in the intake to see if it's fuel related.
    Even if your oil sender is bad though it ought to get fuel for start-up. Does it fire up at all?
    Jun 2006
    Wisconsin
    There's no spark at this point. I checked voltage at the coil during cranking, nothing. Is it possible that when sensing zero oil pressure that the ignition system is shut down?
    I don't think so. Hopefully some of the experts are lurking, I'm just a dodo.
    USA
    no spark usually means crankshaft position sensor dead
    all cars have no oil pressure on starting, and take a while to build pressure on starting, and even longer after the oil is changed, ergo, no oil pressure will not cause a no start condition.
    May 2006
    Perth Western Australia
    No oil pressure can cause a no start, GMH 3.8 v6's (buick to you US lot!) use a 3 pin oil pressure switch which causes the ecu to cut the fuel pump in a no oil pressure situation or 5 seconds after a start if the oil pressure doesn't come up. I don't know if BMW ever used them on the older models but they do on the E60's.
    BMW parts professional
    Previous rides:
    BMW
    E12 M535i (go the dogleg!)
    E28 M535i (MMM M88!)
    E34 535i M
    MAZDA:
    RX7 S-IV T04 (440 hp ATW)
    RX7 S-I 13b bridge port
    RX4 13b peripheral port
    Aug 2005
    I've had something similar happen to me.
    It was caused by the crank position sensor.
    I believe the main computer does not send any fuel, unless it gets a reading from that sensor.
    Can someone more knowledgeable elaborate on what I just said?
    Loving my Problem Child.
    M30 Manual / LSD / Prod. Date: 09-1989 / Basketweaves / Black Leather w/ rear headrests / Alpine Weiss III / 365k kms
    Default Motronics 1.3 does not have a oil pressure fuel pump shut
    down feature. I would suggest you look into the crank position sensor as suggested. Check and see if its loose and has come out of adjustment.
    Jun 2006
    Wisconsin
    Thanks for the suggestions! I'll check the crank position sensor this evening. I have the Haynes manual which provides some fairly detailed spec for testing and will post the results. Thanks again All!!
  1. oil pressure sensor location
    By rockin1978TA in forum 5 Series BMW
    Last Post: 03-06-2009, 05:28 PM
  2. Oil Pressure Sensor Warning
    By uscharalph in forum 5 Series BMW
    Last Post: 08-23-2005, 11:30 AM
  3. Help! Oil Pressure Sensor & won't start!
    By White535Mtl in forum 5 Series BMW
    Last Post: 08-09-2005, 09:04 PM
  4. HELP - Oil Pressure Sensor msg on OBC
    By BMWfreak in forum 5 Series BMW
    Last Post: 05-13-2004, 01:55 PM
