Results 1 to 10 of 16
Thread: Esso LT 71141 Lifetime trans fluid question?
    Default Esso LT 71141 Lifetime trans fluid question?
    How much is it in the USA and where is it available. I need 4L of the stuff for a 5hp18 (a5s 310z) auto trans gearbox. I can only purchase 20L barrel in australia at a cost of aud$380 delivered. The dealer will only sell it in a 20L barrel also. I assume I will use 4L max to replace the old fluid. I talked to Phil Sanderson and mattyb, both of these gentlemen don't want to service their 540i auto transmissions, so what am I to do with 16L of auto trans fluid?
    Edit: I assume I can't use normal dexron 3 fluid and mix it with the lifetime trans fluid.
    Australia
    I did a service on a zf 5hp18 and used castrol transmax z. It's done several thousand Ks now without fault. Its actually much more smooth than the original fluid. The box was on a 94 car, so it was before they started labeling the fuild as "lifetime" fluid.
    I have done the same to my 98 318is, which is "lifetime" fluid, but it is a manual box and I used Redline MTL. Same good results on it.
    Default Sounds like a 5-spd swap would be cheaper....
    in the long run!
    Quote Originally Posted by BigKriss
    Its for an e36 328i, the usa dudes run a GM gearbox, while the aussies get an ZF - similar to the usa e36 m3. Its my mums car, so no changing this one Scott.
    Quote Originally Posted by Scott H
    in the long run!
    Bay Area, CA
    I just pay $100 to drop the pan, change the filter, and then fill it back up with new stuff - all I know is that its penzoil.hahaha.
    Of course...I only have about 6000 miles on it after the change. But it shifts STRONG and SOLID.
    www.KaRealtySF.com
    Default Thats because yours takes only conventional trans fluid
    dexron
    Quote Originally Posted by liquidtiger720
    if its a 5hp-18 shouldnt it take regular dextron III ?
    Default The 94 only required conventional dexron anyway not the
    special fluids
    Quote Originally Posted by myles
    Melbourne, Australia
    Penrite make fluid to suit the 5HP 18 trans... ATF-BMV
    Here's the PDF.
    thanks Rowan. I scared of using it though. I wonder waht Bill R says though?
    Quote Originally Posted by pundit
    Here's the PDF.
  1. another trans fluid question
    By bmwrp8 in forum 5 Series BMW
    Last Post: 02-13-2009, 11:34 AM
  2. Is VW Esso semi-synthetic "lifetime" ATF the same as
    By Dick Schneiders in forum 5 Series BMW
    Last Post: 11-15-2004, 05:23 PM
  3. Theoretical Trans fluid question 5hp-18 530 trans
    Last Post: 09-22-2004, 01:01 PM
  4. Lifetime Tranny Fluid Hah!
    By Tiger in forum 5 Series BMW
    Last Post: 05-28-2004, 11:17 AM
