at first i was going to say capacitors but WOW... I would only be guessing.
This happens randomly, but it's quite puzzling.
Once and a while when I try to start the car, when the key hits the second position the tachometer goes nuts and starts to jump all over, and if this happens, the starter churns but does not fire... What the hell? It will start eentually, but sometimes it takes 10 times to try to get it to start, and it's really embarrasing...what the heck is wrong?
EuroLux:. Private Detail
Seems to be in the ignition system since the tach is goofy. Have you checked for spark when this happens?
Could a bum crank pos. sensor do this??
Hmm, I don't think I can check for spark w/o tools yeah? I think it's mechanic time... *shoots self* *then bleeds on pocketbook*Originally Posted by Ross
Pull off a plug wire and see
sounds like a crank position sensor if its the tach needle.
Could someone find me a part number if possible, I need a quote from the stealer and other places just to see how much it may all cost if that really is the problem...Originally Posted by BillionPa
Thanks!
-Charles
It could also be a fault within the ignition switch itself. E39's were know for it too.
BMW parts professional
Previous rides:
BMW
E12 M535i (go the dogleg!)
E28 M535i (MMM M88!)
E34 535i M
MAZDA:
RX7 S-IV T04 (440 hp ATW)
RX7 S-I 13b bridge port
RX4 13b peripheral port
