Now which is it kngpen....did you buy these parts or take them off your '90 535i? More importantly, did you ever find all the parts that were missing when you posted this?
http://www.bimmer.info/forum/showthread.php?t=2280
Paul Shovestul
95 BMW 525i black/black
-E.A.T. chip
-Blacked out grill and window trim
-17in AC replicas
-Blistein shocks & H&R springs
-Cadmium plated Brembo rotors
-Raybestos QS break pads
Paul Shovestul
[QUOTE]I have had them on my car for about 15,000miles.[QUOTE]
that was fast, hope you changed the oil.
The rear shocks have the spring perches only. The fronts are missing the collar nut deals...someone may perhaps blemish your otherwise perfect Ebay rating. You should either change the ad to say they are missing or pick a couple up and give them in the deal.
Item number: 2455648471 on eBay. He bought them for $350. He is using the other guys pictures and in one of the other guy's pictures it appears that the collar nuts are on the rear shocks. If this is the case, then they are all there. Of course "Mr. Joe" could have lost them in the process. In any case, the price is not that bad and it is ez enough to get the collar nuts if they are missing.
The real deal is probably another case of using Bilstein front strut inserts with their bump stops causing the "whump" over any road imprefection. There is no way I would ever put Bilstein inserts in the front of an E34 again. Koni for me forever.
Mike Holbrook
Spring Valley, CA
