Originally Posted by
gale
Could be the pump impeller is slipping on the shaft, anymore they come with plastic impellers these days. There are numerous brands of pumps: Laso, Hepu, Graf. Laso is supposedly one of the better brands but my new one (Laso) has a plastic impeller. I went ahead & used it anyway since the old one was rusty & the new one has a brass hub sleeve molded into the plastic with obvious signs of serrated "teeth" to keep it from spinning.
Also, thermostats are cheap. Could have gotten a bum one. At one time there was a batch of bad viscous fan clutches (Behr or Sachs?). If it's running hot while sitting at a light, you should be able to hear the fan kick in when you start off again.
