Results 1 to 4 of 4
Thread: Auto Trans fluid...
    Jul 2004
    Perth, Western Australia
    Default Auto Trans fluid...
    Quick question.... Should you check the auto transmission fluid level when the car is running, or when it is not, hot/cold etc???
    I know in previous cars the level should be checked while the engine is idling.
    Garry
    Quote Originally Posted by Mewsy
    Thanks Garry
    Generally running in park, warmed up after a reasonable drive, flat surface. Sometimes dipsticks have a hot and cold level mark to make the job easier. Some e34 trannies have a specific procedure away from this norm, just check your manual for that.
    the pan should be hot, not too hot tho...if you can hold your hand on it and its uncomfortable thats the right temp. Running, level, go through all the gears and then put in park all while idling. Use the correct fluid.
    Jul 2004
    Thanks heaps for your replies
  1. 525 TDS auto trans fluid
    By Tony777 in forum 5 Series BMW
    Last Post: 06-03-2008, 04:32 PM
  2. Replacing E36 auto trans fluid for A5S310Z
    By BigKriss in forum 3 Series BMW
    Last Post: 04-26-2006, 03:20 AM
  3. New Penrite auto trans fluid for ZF transmissions!
    By pundit in forum 5 Series BMW
    Last Post: 11-26-2005, 08:47 PM
  4. VW auto trans fluid
    By kentish in forum 5 Series BMW
    Last Post: 11-12-2004, 06:50 AM
  5. Trans Fluid type for 92 535i Auto
    By monchichi in forum 5 Series BMW
    Last Post: 04-14-2004, 12:16 AM
