Originally Posted by
gale
If you use a wire brush, be sure to use a soft brass-bristle brush. A steel brush could go right thru the platimum plating. Also, I think there must be more than 1 style of O2 sensor leads. My old factory one from the e32 has about 4 feet of cable which are nothing more than 4 separate teflon insulated wires, covered with an outer black PVC shrink tube, which lacks about 1/2" from each end. The connector to the engine/chassis wire harness is nothing more than a plastic "Cannon" connector of sorts, with the pins simply crimped onto the ends of the wires.
The new e36 sensor has a short 12" cable which has a white teflon outer jacket sealed at each end of the O2 sensor and the connector. I guess that must be the type that the TIS cautions against using Stablilant 22a. There's no way my older e32 4-footer is a leak path that could clog a reference bleed.
