Results 1 to 5 of 5
Thread: Upper/Lower control arms
    Default Upper/Lower control arms
    I have new LEMFORDER lower control arms w/7series bushings pressed in
    Should I also replace uppers? Ive heard the lower replacement will get rid of that damn clunk...?
    a clunk is bad, somethings real messed up. usually the upper arms cause the 55-65 shimmy. if your in there I would do them all at one time.
    I think your confusing the upper and lower arms
    USA
    do them both, it will save you the time of taking the thing apart again!
    Orlando, FL (Gainesville)
    a little thread jacking here but I replaced my upper arms bushings the other weekend and for the life of me I couldnt get the ball joint end off. Is there a trick or just brute force? Instead of using a bushing press I ended up using a big C-clamp and cut a steel pipe to make two cylinders. Thank god for air ratchets...woulda been a royal pain to turn by hand...
    Default Its very easy if you do it like this.
    Here is the link
    Quote Originally Posted by GoldenOne
  1. %@#$% Lower control arms & upper boot
    By Asamaan in forum 5 Series BMW
    Last Post: 05-19-2009, 09:54 AM
  2. Replies: 5
    Last Post: 10-07-2004, 12:20 PM
  3. Lower and upper arms...
    By Misha in forum 5 Series BMW
    Last Post: 09-18-2004, 01:10 PM
  4. changing upper and lower control arms at once
    By Stewart E in forum 5 Series BMW
    Last Post: 05-30-2004, 07:20 PM
  5. what is the difference between upper and lower arms
    By kraizytommie in forum 5 Series BMW
    Last Post: 03-16-2004, 12:01 PM
