Thread: Major gearbox problems
    Mar 2004
    Appleton, WI
    Default Major gearbox problems
    Yesterday I was driving along, and all of a sudden my gearbox starts rattling/vibrating quite badly. It's not a violent shake, but it sounds and feels absolutely horrible. It has a sound similar to if you let off the clutch a little early and you grind the gears a little, but not as violent, but it's a constant noise. It's really only noticeable over 30mph.... below that it's not all that noticeable.
    inspection time, hopefully its only the guibo or something like that. anytime you get that its from slop in the driveline, could even possibly be the cv joints.
    Change your fluid to Redline if no major damage visibly seen
    Nashville, TN
    guibo ???
    Derek A.
    90 535i 5 Speed - Style 5 17"
    USA
    guibo = flex disk on driveshaft.
    Quote Originally Posted by Wyn
    Hopefully guibo or centre bearing.... clutch even... ? Good luck! To visually check you have to pull the exhaust and the drive shaft. Any noise transferring from the middle of the car? That would mean less trouble...
  1. M50 E34 Major Oil Leak Help!!!!
    By njshore4x4 in forum 5 Series BMW
    Last Post: 01-08-2007, 02:28 PM
  2. E34 520i 24v major overheating problems.
    By Bob Gorsuch in forum 5 Series BMW
    Last Post: 09-22-2004, 12:50 PM
  3. Replies: 7
    Last Post: 05-20-2004, 09:39 AM
  4. 1994 525i (M50 + 5 Spd) Major hesitation problems.
    By mkii_turbo in forum 5 Series BMW
    Last Post: 04-20-2004, 04:45 PM
