why not measure it ?
I have a set of BBS 18" split rims, I am tring to find out the offset but they dont have an ET number on them.. Anyone have any ideas?
'90 535iSE Auto (AE+EAT) 123k miles
'86 F288 69k miles
'06('89)- PGE 2.0DOHC Turbo
'03 A160LE 19k miles
1914 Stellite E2A (no odometer!)
(+ others I daren't mention here)
www.pyghtle.com
OK, these pix were supposed to be on the other post !
.. you can see from these that if you measure the rim, then its easy to calculate ET
'86 F288 69k miles
www.pyghtle.com
BBS wheel with no ET stamp on it? You are kidding... they always have it stamped on the inside of the wheel...
Originally Posted by Tiger
on that note:
are you sure they are stamped BBS?!
^°^ ><((({º>°°
Thanks for the reply guys, wheel are BBS as it has BBS stamped on to them under the centre cap. I removed a wheel last night to look at the back but there was no ET number.. Under the centre cap is says 18x18 9j is22 I thought perhaps the Germans used IS instead of ET..
John
ET and IS are equivalent.Originally Posted by lamb chops
You have 18" diameter by 9" wide rims with a 22mm positive offset.
Enjoy!
Fusion
Ok thanks for the info Fusion
ET is an acronym for "Einpress Tieffe", which is German for 'push-in depth'
'86 F288 69k miles
www.pyghtle.com
