Probably the float is full of water and does not float. Use a flashlight and see if it floats or hangs.
Also remove the plug from the sensor and bridge it with a short cable. Then the alarm should disappear. If not, probably the thin wires are broken.
Check also if the float is correct installed towards the bottom.
