How does the car jump when it is out of gear?? I have had the chip for a while and have not had ANY problems whatsoever
I recently installed the EAT chip for my 1994 530i and have noticed when i go to change gears and press the clutch pedal down my rpm's seem to go up maybe by 150. I only noticed this since when I was testing out the car afterwards it would "jump" due to the increase in revs when the car was taken out of gear. I was wondering if this was normal or is there something possibly wrong?
It jumps when you are engaging the next gear, but when i take my foot off the accelerator and the clutch pedal is pushed in completely I noticed the engine revs about 150 rpm higher and thus when i put the car into gear it has a tendency to "jump". It might just be me needing to adjust my driving habits but this never happened before i had the chip.Originally Posted by kiNGMak
The chip can't cause that problem. It sounds silly but check to make sure your throttle pedal is clear of the carpet. Sometimes it comes loose from the clips and slides up binding the pedal down. You could also have a sticking butterfly...
Originally Posted by Sardaukar
Check for a sticky throttle position sensor.
Bellevue WA
86 Porsche 951 - Track Toy
the chip raises the idle to smoothing it out.. it shouldnt "jump" from only 150 rpms... 1000 rpms is a problem
Thanks all, I will look into all your suggestions. As for the carpet issue, i've had that happen before hehe. =) Funny thing is this has never happened before I got the chip, but i suppose thats not the problem.
