Results 1 to 4 of 4
Thread: Lowering Springs
    Aberdeen, Scotland, UK
    Default Lowering Springs
    OK guys today i replaced my broken drivers side spring, with a set of 40mm lowering springs up front, but on trying to do the rears, i cant get the lower shock mount to come off. HELP any tips for removing the lower shock mount??? i removed the whole rear seat, loosened the top mount nuts, took ages to get the rear seat back rest out but got there in the end.
    i got the bolt out no problem, but the shock is stuck firmly in place.
    other than this the car looks good, front nice and even now, both low!! no noise from the suspension now either, and not too firm.
    Iain
    1993 BMW 525 TDS SE 150K 2.5 Turbo Diesel, performance air filter, lowered sports suspension 30mm, full stainless decat exhaust, boot-lid spoiler, OBC retrofit, E60 Trapezoid alloys
    A little heat, large prybar, PB Blaster, and sometimes, a big hammer. These days, when they're really rusty, I usually spend some time on it with an air hammer.
    Read my writeup for other ideas: http://www.bmw4life.com/suspensionLowellRA.htm
    Quote Originally Posted by iainand
    Bolt as in the lower bolt? All three nuts removed from the top? hit it with a mallet to drop it out if its stuck, but it should just fall out.
    finally got the shocker off, undid 1 dog-bone bolt, to let trailing arm fall down a bit more, used a puller on lower shock mount, and finally off it came
    other side was much easier, the shocker took the sleeve inside rubber bush with it, done in minutes!!!
    old rear springs must have been sagging a fair bit, the 40mm lowering ones are about the same height!
    car rides much better now, corners a lot better, and without a broken front spring is much quieter too! and thankfully not too hard or harsh
    Iain
  1. Lowering Springs
    By Kobe Diesel in forum 5 Series BMW
    Last Post: 01-12-2006, 02:44 PM
  2. lowering springs
    By Rory535i in forum 5 Series BMW
    Last Post: 07-10-2005, 12:07 AM
  3. e34 lowering springs
    By crunchy in forum 5 Series BMW
    Last Post: 04-19-2005, 05:01 PM
  4. WTB Lowering springs for e34
    By sooperspeed in forum 5 Series BMW
    Last Post: 10-12-2004, 12:27 PM
