Results 1 to 2 of 2
Thread: 750 Engine Seal
    So Cal
    Default 750 Engine Seal
    Can someone tell me how hard is to replace all of engine seals in 1990 750il.
    And, by replacing the seals would the car stop to over-heat?
    Do you really mean ALL???
    In that case you have to disassemble the complete engine. If you cannot do it, it will cost you more than the car is worth.
    What is the problem with over-heating? Can you explain that more in detail? Is one or 2 headgaskets damaged? Is the engine losing water/coolant/oil?
    Are the coolant hoses hard as if pressure by exhaust gases has been built up in the coolant system?
    Have you replaced the thermostat, water pump, fan clutch?
    When does it overheat? Only in traffic jam or always, even when you drive Highway?
  1. M30 Crankshaft Seal
    Last Post: 10-05-2011, 06:26 PM
  2. Tranny oil seal
    Last Post: 06-24-2008, 05:33 AM
  3. inner door seal
    By MB535 in forum 5 Series BMW
    Last Post: 03-13-2004, 06:43 AM
  4. New Radiator Won't Seal...?!?
    By Aaron Bakos in forum 5 Series BMW
    Last Post: 03-12-2004, 06:26 PM
  5. To seal, or not to seal...
    By NoSpeedLimits in forum 5 Series BMW
    Last Post: 02-25-2004, 12:52 PM
