most def. want to get it hooked up to your laptop to see what the actual temps. are.Originally Posted by Jon K
This is true. Since the driveway is slanted, it makes the car look a tab bit lower. The true height of the car can bee seen in the airport pictures.Originally Posted by Jon K
Actually Jon, I had it replaced in November of 05.Originally Posted by Jon K
i am assuming you still have your AC condenser installed?
when i removed mine there were tons of leaves behind it blocking the radiator.
Originally Posted by BillionPa
yes, I still have the ac condener isntalled. I don't believe it's a blockage of the radiaot because it started hapenning 2 weeks after the water pump was relaced, so myabe I'll make a trip over to the guy who did it asking what his procedure is. I don't understand what could go wrong with installing a waterpump that would make it slightly overheat in traffic though.
crappy aftermarket pump? reused old gaskets?
Nah, I doubt it. The guy's a master BMW mechanic and he used all new seals.Originally Posted by BillionPa
All birds should have their arsholes sewn up!
