Results 1 to 10 of 11
Thread: Who has removed injectors? What's the trick?
    Apr 2005
    IL
    Default Who has removed injectors? What's the trick?
    At first glance the electrical connectors look like other quick connects ... but their not. How do you remove the electrical rail without damaging the injectors or the connectors? What's the trick? I've destroyed connectors in the past due to brittle plastic and do not want to do it again. Chiltons and Bently say simply pull off the rail, not mentioning the spring clips.
    Ken
    you can try to use a screwdriver to unhook the clips and pull the rail from one direction or another. Before I learned this I just yanked the fuker out and broke all the clips with no adverse effects.
    Quote Originally Posted by zuzuk212
    Ken
    Honolulu
    Default On the M20
    is yours are the same...They pop off
    But like you said the plastic can be brittle, so use caution and gently start from one end and get the plug between two fingers and pull up with a wiggle.
    Don't forget to un due the harness or you'll only go so far before it holds you back.
    I did the same thing as Jeff, but in a more gentle fasion. Putting them back on wasn't as bad. Derek
    Apr 2005
    IL
    Thanks guys! I'll give it a shot, just wanted to double check before breaking crap.
    Thanks again,
    Ken
    Meridian, ID
    The injector clips are exactly the same as the clip on the temp sensor just to the front of the injector wiring cover. Basically, you pull up firmly and they come undone. I have broken one clip but not a problem since I used the piece from the temp sensor to fix that clip. Some day maybe I'll get a piece from a wrecker.
    Mike Holbrook
    Meridian, Idaho
    PA
    My electrical connectors just let go, no clips to pop off really. I undo the circlips by hand on the fuel rail.
    USA
    the clips are a dollar new....
    Rock them back and forth while pulling on them, they should pop off. You can also use a dentist pick to undo the clip if you don't have the type that can be released.
    Tampa Bay, Florida, USA
    I sprayed Radio Shack Contact & Control Cleaner and Lubricant into each connector before unlocking and pulling them off. They slide right off. It loosens up the years of crud off of the connector. Cleans it off for the install too.
    Ramon
    1994 540iA Nikasil EAT Chip
    Tampa Bay, Florida USA
  1. windows up key trick..??
    By bigmuthatrucker in forum 5 Series BMW
    Last Post: 09-21-2006, 09:30 AM
  2. whats the trick?
    Last Post: 07-09-2006, 07:08 PM
  3. Trick codes?
    By stx133 in forum 5 Series BMW
    Last Post: 07-25-2005, 04:34 AM
  4. Maintenance Trick
    By MicahO in forum 5 Series BMW
    Last Post: 03-28-2004, 08:13 PM
