Results 1 to 7 of 7
Thread: e39 540 CEL
    Bay Area, CA
    Default e39 540 CEL
    Hey guys,
    I know this is mainly an e34 forum, but I finally made the jump to an e39 540. I know the cats need replacement, I bought it knowing this... however whenever the car gets in the upper rpm range, I get a CEL - The OBDII scanner says: Cylinder 2 misfire detected.
    I cleared it once, it stayed away for a while, and now that I went back into the upper RPMs, it's back. Same code.
    Does anybody know of a probable cause? Would a bad coil cause a misfire only at the upper RPM range? Could this be cat-related?
    Any and all advice / comments would be greatly appreciated.
    Thanks!
    edit: is it possible that a generic scanner is reporting an improper code?
    Sep 2005
    MI
    I'm not sure how similar the ignition systems are, but I had this problem on my '03 Land Rover (V8, wasted spark, 2 coil packs [shoved so far behind the engine not even Mr. Fantastic could get to them]). I'd clear the codes and it would be fine in idle, but once I got it up to speed on the road it would say a cylinder was misfiring.
    Changing the plugs didn't help me, and when I was changing the plug wires the old ones all tested fine for resistance. But when I was all done changing the wires, it never gave me another problem.
    Let us know what it is once you figure it out.
    Job 14:1 Man born of woman is of few days and full of trouble.
    az
    PA
    Switch the coil packs around, move #2 to #8 or something, then see if you get a misfire on #8
    Great idea.
    a weak spark will blow out at higher rpms, could be a coil or simply a fubared spark plug.
    Bay Area, CA
    Thanks for the advice..
    does anybody know how i can identify which is cyl #2?
    PA
    I think it goes 1 2 3 4 front to back on pass side, 5 6 7 8 front to back on drivers side
