Results 1 to 2 of 2
Thread: Want something else to clean??
    Hobart, Tasmania, Australia
    Default Want something else to clean??
    Don't know if this is common knowledge, or whether peeeps have cleaned this spot before but...
    I was tipped off to this by my Dad when he was washing his E34. The seal around the trunk/bootlid collects a fair bit of grime, as does the strip along the bottom of the rear window. Both can be pulled out (although I didn't remove them completely just in case...), and the grime can be sprayed with some cleaning solution, then wiped away, or use a toothbrush. The white clips you can DO move, and aren't that difficult to remove or put back in...
    The pics below (sorry if they are too big) show where the grime was. I decided to let you all know, as it could be a possible spot for future rust.
    I hope this info helps someone...
    Gone but NEVER forgotten. :'(
    And then...
    Norway
    thanks for the heads up. Im not finding it hard to believe that this is a potencial rust trap.
  1. Clean!!!
    By bmwrp8 in forum 5 Series BMW
    Last Post: 07-03-2007, 09:53 PM
  2. How to clean MAF on 90 535
    By wjbell in forum 5 Series BMW
    Last Post: 04-02-2007, 02:03 PM
  3. Nat. Clean Your Box.........
    Last Post: 01-24-2007, 12:37 PM
  4. clean my beams?
    By bigtallsam in forum 5 Series BMW
    Last Post: 03-26-2006, 07:59 AM
  5. What do you use to clean your engine?
    By thunderman in forum 5 Series BMW
    Last Post: 04-03-2004, 09:01 AM
