If you are trying to take off from 15-25 MPH in fourth or third, I don't think you will have much grunt. You will be lugging the engine until it reaches the happy zone above 2K. I assume this is a manual trans? I can somtimes cheat and get into third at 25MPH using easy acceleration (and this would be on a level surface). But yes, if you have a bad rotor / cap / or wires, it could affect your idle. I dunno when they started the direct coil ignition on the 535 though... ICV? Valve Cover Gasket? FPR?Originally Posted by Black 535i
