Fuel pump seems to be overpowering the FPR or the FPR not controlling the flow and causing flooding or at least gross over rich running. Very rough runnng and no power. !/2 block from home more than enough road test.
1) Pulled both vac and return lines on the FPR. Engne started right up, idled OK, fuel flowing from jury rig return line into a container. No flow from the Jury rigged line from Vac port on FPR.
2) Tried again as (1), but no flow from the return line.
3) Tried to start with FPR vac line attached to manifold, no return flow.
What the heck can be happening that FPR worked correctly (1), then blocked all return (2) and (3)?
Can't do pressure test until I rebuild another FP test rig, but tests (1) to (3) are indications of what must be happening, no control of return flow.
