535 M30 US comes without a cooler
M5 3.6 US comes with a cooler
The oil fill capacity and oil pump are the same for both motors. It must not cause a significant change or else BMW would be using different parts and fill specs for them. I have not had an oil pressure gauge on the M5 yet so I cannot provide an actual number.....I should probably get an oil pressure gauge on that thing now that I think about it! The pressures I see on the new pump in my M30 are 60psi >3000rpm and 20psi at idle with oil at 210F
Originally Posted by Robin-535im
