Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Restore Engine Performance
    Aug 2005
    Iowa, USA
    I think i have bad news for you, your transmissions bouncing between revs, is called pendulum shifting, do a search on it, i have it too, it will only get worse. our cars have bulletproof engines with **** for automatic tranny, going into sport mode (s3) while you are accelerating to your desired cruising speed will help.
    Nov 2005
    los angeles
    is there anyway to reverse the effect? and is s3 A or M on the lil switch board next to the shifter or 3rd gear?
    If your transmission slips, the RPMs will increase, not decrease. As was stated above, you car is doing what is called pendulum shifting. this is when it hunts back and forth between 2 gears.
    There was a service bulitin released to address this issue, and required replacingthe valve body. This is an expensive part, but far cheaper than a rebuilt trans. If you do decide to go with a rebuild, I do not recomend you rebuild the one you have, since you will have to get a new valve body ontop of the regular rebuild cost. Get one from Kurt Koehler, it will have all the updated parts and is affordable. He is a board member, so searrch for his name.
    Aug 2005
    Iowa, USA
    with your transmission in regular A mode, if you move the lever to 3 you will be in sport mode, your gear indicator on the dash will indicate S3, in sport mode you have higher revs before shifting and you wont shift into 4th gear (overdrive)
    Quote Originally Posted by hoodsstalker
  1. Replies: 2
    Last Post: 06-15-2008, 10:54 PM
  2. OT Computer XP Restore Help
    Last Post: 10-21-2006, 09:43 PM
  3. Restore Engine Performance
    By hoodsstalker in forum 5 Series BMW
    Last Post: 06-02-2006, 06:21 AM
  4. The One to Restore
    By jbeary in forum 7 Series BMW
    Last Post: 07-16-2004, 07:47 AM
