Results 1 to 7 of 7
Thread: Soft faced pliers for FPR diagnosis?
    Apr 2004
    Default Soft faced pliers for FPR diagnosis?
    Soft faced pliers for clamping off fuel lines? What are soft faced pliers or what is alternative method for solid clamp off at 40+ psi?
    Working on FPR diagnosis. Tip calls for fuel press guage inline at fuel rail, start eng, eng off, clamp input and return with soft faced pliers to detect leak in injectors or ruptured diaphram leaking into intake manifold.
    I just use a pair of vice grips. just keep adjusting the pressure until you feel the hose compress. I have some special hose clamps, they are a piece of fat wire bent at 90 degress with a pad to clamp against and has a wing nut. They work really well, I normaly use them on brake hoses when removing calipers.
    Pittsburgh, PA
    i used vice grips also, to replace my fuel filter, worked perfectly
    Present: Black 1995 525i | Past: Red 1989 535i; Black 1985 535i
    Seattle, Washington USA
    I love my Vice Grips!
    Josh
    1990 BMW 525iA
    2000 Toyota Corolla CE
    2007 Toyota Echo
    Hockinson, Washington
    I was afraid to use anything to clamp the hoses when i replaced the fuel filter, as the hose is original and i would be afraid of cracking it, and i only had enough hose to replace one. If the fuel pump fuse is removed while the engine is running, there wont be much pressure at all in the lines, and you probably wont make any mess at all if youre careful and you have a bolt or somehting of the right size to stick in the end of the hose. I would think that any sort of clamping or pinching would shorten the life of any hose dramatically, although it is easier and faster.
    Jul 2004
    For changing the fuel filter, I use a set of Snap On (Blue Point) Hose Pinchers:
    http://buy1.snapon.com/catalog/item....store&tool=all
    Default I have a pair othem made by lisle that have a sliding clamp on the
    handle with plastic jaws,you squeeze them and then slide the ring on the handles down to hold them shut with just the right amount of pressure. I also use vice grips with a short length of 5/8 heater hose slipped over each jaw about 2 inches long for each piece. This makes it so that you have some nice thick rubber hose squeezing the fuel line with no sharp edges that could cut into it.
    Quote Originally Posted by Gene in NC
  1. Soft On/Off Interior Light Retrofit
    By Jr ///M5 in forum 5 Series BMW
    Last Post: 11-25-2008, 09:44 PM
  2. Clutch Pedal is WAAAAYYYYY too soft.
    By icesoft in forum 5 Series BMW
    Last Post: 04-30-2007, 08:50 PM
  3. Soft Clutch on Highway solved
    By DanDombrowski in forum 5 Series BMW
    Last Post: 11-30-2005, 10:28 AM
  4. Soft swaybar bushing broken
    By JonE in forum 3 Series BMW
    Last Post: 08-17-2004, 10:13 AM
  5. Anybody try Vogtland springs? Harsh? Soft? How Low?
    By rockyfeller in forum 5 Series BMW
    Last Post: 05-04-2004, 10:53 PM
