![Quote](images/misc/quote_icon.png)
Originally Posted by
Alexlind123
I was afraid to use anything to clamp the hoses when i replaced the fuel filter, as the hose is original and i would be afraid of cracking it, and i only had enough hose to replace one. If the fuel pump fuse is removed while the engine is running, there wont be much pressure at all in the lines, and you probably wont make any mess at all if youre careful and you have a bolt or somehting of the right size to stick in the end of the hose. I would think that any sort of clamping or pinching would shorten the life of any hose dramatically, although it is easier and faster.
