Results 1 to 2 of 2
Thread: driver side window
    Yorba Linda
    Default driver side window
    The drivers side window on my 1990 535 will not go up or down- is it:
    1. switch?
    2. motor?
    Mar 2004
    tampa fl
    could be either check for power coming in and out of switch when button is up or down position if you have both in and out power than most like its gonna be your motor or track then you gotta take your door panel off and check it. if you have no power coming out of the switch then its your switch
  1. Driver side front window issue
    By Al Gray in forum 5 Series BMW
    Last Post: 07-15-2006, 10:32 AM
  2. One touch driver side power window function
    By ktteoh in forum 5 Series BMW
    Last Post: 06-23-2006, 06:25 PM
  3. No heat from driver side
    By beetos in forum 5 Series BMW
    Last Post: 05-17-2006, 06:29 AM
  4. Need help with driver side front window
    Last Post: 04-08-2006, 03:21 PM
  5. Replies: 2
    Last Post: 07-02-2004, 03:09 PM
