if i am already there is it worth changing out and how involved is it to change???what about thermostat???
the frez plug was leaking on mine and ended up backing into the cam gear before i adjusted mine tooOriginally Posted by diamond777
Some beatup BMW with 20" Nipplewheels
it's an easy job, just make sure you get the gasket ahead of time.Originally Posted by diamond777
there is a gasket for the freeze plug????
no gasket, use teflon tape so it doesnt leak out when its hotOriginally Posted by diamond777
ok ill bite what is the rocker arm adjustment ??-replaced water pump and noise still there tia
