I now have 133,000 miles on my 5HP30 and no issues. As some of you have researched my previous posts, the Pennzoil MVATF looks like a good candidate for the Shell LA2634 replacement. I've got 22,000 miles on the MVATF (111K-133K) and the transmission shifts the same as it did at 111K.
As I've posted before, I wonder if a lot of the hesitation on using alternative fluids is due to pride issues. Some people can't get over the fact that they overpaid for something and will rigorously defend their decision just to save face. I admit, I overpaid for a lot of things in life. There, I said it. Lets move on and learn from it.
If the chemical (ATF, motor oil, coolant, whatever) is compatible and endorsed by the manufacturer's, what's the issue? If someone tells you that you can only use Mobil 1 5W30 oil in your car otherwise your engine will fail, would you believe them? Some people that like to brag about paying large amounts of money for things probably would!
As we all know the specs between Mobil, Amsoil, Valvoline, Shell, Pennzoil and others are different (i.e. ash content), but most of you wouldn't hesitate putting in a quart of any synthetic 5W30 oil in your car if it needed it.
I'll be changing out my wife's E38 750iL 5HP30 fluid in the next couple of weeks. The trans calls for Esso fluid but, being the red-headed stepchild that I am, I'll probably spring for the Mercon V or Pennzoil MVATF fluid. The 750 has the original fluid and 167,000 miles. If that doesn't convince someone, I don't know what will.
