I too wonder if they fit! Anyone knows?
Hello all. I am looking to get black door panels for the E34. I have come across a set of 7 series panels that look really good, and molded same as the E34. Will they fit? backs look a little bigger, but the fronts look about the same size. Any help would be great....Thanks Derek
('94 525 Tds Touring - from GR - Switzerland)
If it's from a stretched 7 (e.g. it's has "il" after the number designation) then the rear doors are much bigger than yours.
I dunno about the standard-length 7, though. Most of them were the long version.
No, nothing about the rear 1/2 of the E32 trim, with the exception of the reading lights and the grab handles, can be swapped into an E34.
best, whit
I kinda figured the rears won't work, but you think the fronts may work? if so that would be great. The 7 series to me have a cleaner look. smoother around the edges.
I seriously doubt it, check the dash vents where they connect to the door trim for a fast check. If they are in the same position, you may be in luck- but the whole loook is different, i doubt they would mate properly to the dash or look right if somehow they could be made toOriginally Posted by Felixdacat
