Results 1 to 2 of 2
Thread: m30 vacuum hose question.
    Chicago
    Default m30 vacuum hose question.
    Just got done replacing cylinder head and need to know where two (2) hoses go. The small hose from the fuel pressure regulator goes to the intake manifold so I've read...but where? There is also a hose already at the bottom of the intake manifold..does it go to the vent hose off of the cylinder head cover?
    Quote Originally Posted by BMW-F1-FAN
    There's two male connection's on the bottom of the inlet manifold where you carn't see them.
    One go's to the fuel regulator,the other go's on to your crank case breather pipe that runs from your valve cover to your intake belows(pipe) or at least that's how it is on UK 5's.
    HTH
    Andrew
  1. Vacuum Hose to the FPR
    By Jeff N. in forum 5 Series BMW
    Last Post: 03-24-2008, 05:51 AM
  2. vacuum hose
    By dolfan13 in forum 5 Series BMW
    Last Post: 12-16-2006, 09:53 PM
  3. Trying to ID vacuum hose part #s
    By blee in forum 5 Series BMW
    Last Post: 08-28-2006, 03:47 AM
  4. M60 Brake Vacuum Hose
    By MBXB in forum 5 Series BMW
    Last Post: 12-29-2005, 04:08 PM
  5. What's the vacuum hose under dash?
    By grr in forum 5 Series BMW
    Last Post: 12-15-2004, 01:53 AM
