Results 1 to 10 of 13
Thread: Hubcentric rings necessary on stock wheels?
    Missouri, USA
    Default Hubcentric rings necessary on stock wheels?
    I have the BBS-style (I believe that is what they are) stock wheel on my 1993 525i and when I was doing the rear brake job, I noticed the car has hubcentric rings on the back.
    The fronts wheels do not have the rings.
    Do STOCK wheels need them?
    On the E34 site, they mention the rings for retrofitting different-than-stock wheels.
    I'm chasing some pesky vibrations and was wondering if this is something I need to address.
    Thanks for your help.
    Sacramento Area
    Hubcentric rings are used when putting e39 wheels on an e34.
    NE GA
    Some aftermarket wheels such as Rondell use them too. You might see if the rings fit inside the hub bore of the front wheels and carefully try to install them.
    JR
    1992 525 IA, EAT chip, 16 x 7.5 Rondell 58's, BavAuto Springs, Bilstein Sports, Elipsoid Smileys & fogs, Z3 Pistol grip shifter, 4 VDO gauge package, Azure Blue w/nice patina - clearcoat shot
    Missouri, USA
    Default Maybe previous owner(s) had aftermarkets?
    Quote Originally Posted by JR'Z 525
    JR
    At some point.
    I was just concerned whether I needed them all the way around, since I only have them on the rear right now.
    I am chasing a vibration issue right now and I'm just trying to narrow down the possibilities before I throw more money at the car.
    Sacramento Area
    What is the correct way to install the hubcentric rings?
    (i have a set with 18" wheels now wondering if i did it right)
    Unregistered Guest
    Quote Originally Posted by Deke NorCal
    I always place the ring inside the wheel hub first and then slide the wheel + ring onto the car as a unit
    NE GA
    Default Something else to think about...
    My Rondell's came with plastic hubcentric rings. I wasn't too hip on plastic rings so I got a set of aluminum rings from Tirerack. I was really surprised to discover that the car rode much worse. When I got home I jacked it up (not using the crossmember of course..) and took a closer look. Seems the bore of the Rondell wheel is just a fuzz larger than the outer diameter of the metal rings. I didn't have a micrometer handy but the plastic ring appeared to be thicker than the metal ring. I have a spare set of plastic rings on order at Bekkers. Although you think you have the stock type BBS wheels, I hope you don't have the same type thing going on with them. Wonder why there was only one ring on the RR?
    JR
    Rick L Guest
    Default I put it on the wheel hub center first.
    I put it on the wheel hub center first. Then, put the wheel on the hub. I also put some grease on the hub so it doesn't rust and becomes hard to take off.
    QUOTE=Deke NorCal]What is the correct way to install the hubcentric rings?
    (i have a set with 18" wheels now wondering if i did it right)[/QUOTE]
    Missouri, USA
    Default In conclusion....DO I NEED THEM?
    Quote Originally Posted by MO525
    It sounds as if I don't, since I am using the STOCK BMW wheels for my '93.
    Thanks again, folks.
    Default stock E34 wheels you wont need them,
    as for vibration... Been there done that and still am there. A slight shimmy could be many things, tires that arent round, good for a Cadillac but you dont have one, a bent rim, dirt or other stuff on the mating flanges between the rim/rotor/hub, not torquing the rim without weight on it (dont ask) and finally worn thrust arm ball joints (usually more severe). I'd guess that you also have square tires, I havent been happy with my tires since I bought them and the ones that were really bad i deflated and drove on til they were real hot in an effort to get a free replacement. Still have 2 tires that arent round and it pisses me off, Discount tire sucks but so do a majority of others, if you know someone at a tire store become buddys and have them spinn the tires, look and see how out of round they are, youll probably be surprized. Try to switch them around till the shimmy lessens and you isolate the bad offenders and then go to the tire joint and complain.
  1. hubcentric rings
    Last Post: 07-04-2007, 06:57 AM
  2. For those with hubcentric rings...
    By GJPinAU in forum 5 Series BMW
    Last Post: 12-30-2005, 05:29 PM
  3. Hubcentric rings?
    By araine901 in forum 5 Series BMW
    Last Post: 05-10-2005, 05:13 PM
  4. hubcentric rings w/ stock wheels?
    By silverz06vette in forum 5 Series BMW
    Last Post: 10-22-2004, 10:35 PM
  5. Need HubCentric Rings - E39 to E34
    By talltorontoguy in forum 5 Series BMW
    Last Post: 04-16-2004, 01:17 PM
