Prob cleared. Replaced wires with "known good" Bosch with maybe 90k + mi. Last symptom of stumble at 4k rpm in 2nd cleared. Interesting to note now that the 2nd gear hard accel stumble was the original indication
"Known good " wires were from the our other '89 that showed wire like probs on heavy acceleration. Replacing wires no help. Went through an awful lot of time and expense before very careful improvement of grounds, including use of Stabilant, gave some relief. Finally cleared up with new dist cap and rotor.
Note we are talking about two '89 525s here. One long term from 36k to 150k, the contributor of the used wires and related experience and the 186k 5s that is the subject of this thread.
Thanks to Joshua for tips and to Jeff for reminder in line with wisdom of the ages on cars, "If you think prob is fuel related, start with the ignition."
Take away: $250 for dist cap, rotor and wires is not cheap but if the prob "Looks ..., walks... , and quacks like a duck (ignition miss) it might just be .........". Might have gone for aftermarket before but never again.
