Rear Windows Don't Work
OK, now that I've got the brakes and headlights done, I'd like to get the rear windows working. When I bought the car a couple of months ago, they worked fine. Salesman said the dealer had replaced the window switch. All fine and good. Then a couple of days later, they quit, so I brought the car in to get that issue cleared up. Literally, the car's in the service bay for about 5 minutes when they come to get me. The salesman explains that the switch is fine, they just tapped on the panels on the rear doors in a certain place to make the connection work and the windows are fine. So, in order to avoid spending any more money, I take the car and go on my merry way.
Sooooo. Now that they're not working again, and assuming that the switch is OK, I'm guessing corrosion or a loose connection in the harness on the door itself, yah? Is it worth peeling of the door panels to check the harness? Anything else I should look at? Front windows work fine.
When I try to roll down the rear windows, the lighted switch goes dark and I hear a relay click, but the glass doesn't move, if that helps narrow things down a little.
Thanks in advance, as always.
-Zak-
1995 525iM - 131k - Alternator play, broken s-belt
1995 525iA - 147k - Tensioner weirdness, broken s-belt
2001 Intgra GS-R - 130k - spun bearing
2002 Honda Odyssey - 80k - fragged transmission
