looks easy!
Just happen to have that link:
http://www.tycksen.com/bmw/tech/subf...dJKvYmZGw3itv2
Ramon
1994 540iA Nikasil EAT Chip
Tampa Bay, Florida USA
looks easy!
I used the cut out method to get the original stuffed mount out. The problem was trying to press the new one with water as a lubricant as everyone suggested got stuck half in, half out. I didn't want to then cut out a new mount that Patrick had sent from US to Sydney. Eventually I used the wooden blocks, lowered the car to use the weight as a press and then an engineers hammer to add some vibration.
Now I'm in search of a rubber lubricant. BMW Aust couldn't suggest anything here that would work.
Perhaps Lanolin? You want the right stuff tho. Door rubbers come covered in talc I think- what is it made from? And what is that P-80 stuff made from?
PBR makes rubber grease, you can use it in brakes etc. it is rubber and plastic friendlyOriginally Posted by John 535is (Sydney)
got a couple of tubes to fix the brakes on the e28.
is that what you're looking for?
bma or one of our freinds stateside might have to send you some of that stuff that bill r said.
Gone but not forgotten
the key (no pun intended) is the grease has to disapear again
ah yes i remember that stuffOriginally Posted by Paul in NZ
Don't buy the PBR stuff then!
what bmw uses. Its the 3rd or so item down on this link
