Results 1 to 10 of 16
Thread: Who has had their engine pipes off a big six?
    Default Who has had their engine pipes off a big six?
    Engine pipe hardware question that I've been trying to work it out for a while to no avail.
    On my M30 the engine pipes have no sealing rings. The tops of the engine pipes -where they connect to the manifolds- are flared and these flares mate to machined surfaces on the manifold output flanges. There are 2 pairs of stainless studs in the manifolds that stick out a good 50mm to allow a bracket to go on each pipe which is then secured by a compression spring and nut on each side of it.
    I guess the springs help to manage movement if the pipe is forced is forced yet always bring the surfaces back to square with the right pressure on them to reseal.
    Some engine pipes I have seen have flexible joints in them also. I believe many other M30 engined e34s have seal rings instead of bare machined surfaces. Does nayone know why various cars are different?
    Mine is RHD, but I believe this is not the only factor.
    Many thanks, Nick
    000000====))====CATS=========RESONATOR===MUFFLER=
    Here is the bit I am talking about, I expected it to have seal rings, not mate straight up bare and use a pair of springs to load the surfaces.
    Jul 2004
    Quote Originally Posted by genphreak
    Many thanks, Nick
    I disconnected the pipes a few times. My car too did not have the rings as I expected. The springs are used to provide flexible connection in order to keep contact while the engine is allowed to move sideways a bit. The ends of manifolds and the pipes are spherical - for the purpose of providing ability to move while avoiding leaks.
    __________
    P.S. I tried to contact you regarding AFM procedure - please take a look at the replies in that thread. Your inbox was full.
    deleted air conditioning
    Dec 2005
    Brisbane Australia
    they probably changed the design to have the sealing rings to allow them to increase the tolerances. i am wondering what the deal is with the spring. can't really say because i haven't seen what type of nut is on it or how stiff the spring is.
    actually just out of interest
    how long is the stud? it says here 87 or 95 mm
    which might suggest that'd get pretty elongated underheat.
    how thick at the flanges each? and the spring is not inbetween the flanges is it?
    Quote Originally Posted by rob101
    Rob the studs are awesome SS, they still look new after 17 years. and are 10" as the exhaust flies from the closest exhaust port. They cost a bit from BMW, so check twice before buying them. For the price of 20 studs in Aus, you could ship a set of extractors from the US or get half way to a turbo if you were up to making your own manifold. The nuts are 12mm M8 or so, appear like copper, but are not- or maybe they are some special harder copper/zinc/mix type alloy. They are the same ones as used on the exhaust side of the head (12) and to bolt up the cats (4 more) - that makes up about 20 on a car at like $1.20-$2 each from the Au stealer.
    The 4 springs on the other hand are stainless also, also very good quality. If monkeys tighten them to far, time and heat relaxes them and they shorten under the compression, that is the only way they will need replacement.
    It is very common for cars to not use gaskets or sealing rings at the downpipe to manifold junction. Every manufacturer has has its own method of dealing with engine movement, flex, and expansion. The flex pipe has a shorter lifespan but is cheap to make. The ball and socket type seems to last the longest but it is more expensive to manufacture. Adding a sealing ring to the junction would only shorten the lifespan of the joint, and since it is not needed, they are normaly left out. I like to coat the flared end of things with some high temp copper antiseize, this not only helps the pipe seat easier under spring load, but will help prevent any groaning or squeaking that this type of joint sometimes has.
    The nuts are made from a copper alloy and should be replaced each time they are removed, but in practice can be re-used sometimes. They require very little torque to hold. If you can't find BMW nuts, you can use the VW type nuts, or double nut. Either way, never overtighten the nut onto the stud and never use steel crimp or nylon lock nuts.
    Jul 2004
    Quote Originally Posted by joshua43214
    Can you please tell why Josh?
    Awesome explanation Joshua, thank you for enlightening me so. Now I know why these nuts came loose- I had put a used one on and obviously this is a bad idea. I guess anti-seize is not necesary on new nuts either-perhaps that is why 2 came loose. But then again, it could be the springs- 2 of mine are deformed so are not doing their job anymore. When I took it to the shop to replace the exhaust they did them on so tight they deformed the springs and ran the nuts up the unthreaded section of the bolt, partially stripping the nuts. I replaced with new nuts but not new springs, they are bloody expensive from the Oz stealers.
    Has anyone some spares?? They look ike this (pic is not my car btw, its that E30 with the M70); it shows the studs really well at the top of the pic.
    Dec 2005
    Brisbane Australia
    mate i wish i had SS studs on the m50 manifolds
    one bloody bastard nut got stuck and stripped a stud so i had to pull the manifold off.
    a very interesting setup, i must say i am only familar with 2 flanges sandwiching a gasket myself for the manifold to front pipe joint. (ie M50 and CBR 610 cc engine with a custom manifold (FSAE car))
    the expense of manifacture as has been pointed out (because of tolerances) i think is the reason why you see the rings and gaskets on other e34s.
    PS after 14 years my studs looked like shite,
    just goes to show they didn't make the m50s etc. like the m30 (idol of bmw engine engineering)
    one bloody bastard nut got stuck and stripped a stud so i had to pull the manifold off. PS after 14 years my studs looked like shite, just goes to show they didn't make the m50s etc. like the m30 (idol of bmw engine engineering)
    Nah... M30 was just made for so long they had heaps of time to iron out the little things like this the right way. I was amazed to see studs that came off the car so easily. But to be fair exhaust shops wreck them too. They don't bother using new nuts or using anti-seize or anything like that- whack it off and if it fits back, whack it back on again. I regret the day I went to see those guys at HiTech mufflers, a little while ago Kriss and I were changing the centre bearing and I was glad to have the opportunity to pull it clean off and refit it properly. However I found that it was impossible to refit properly. They had bent the rear pipes incorrectly in the first palce and mangled the supports to give it more clearance. No wonder I had taken it back twice already and it still banged something underneath the car. I felt like going back and hassling them real bad but I can't risk them touching my baby again... Nick
    Dec 2005
    Brisbane Australia
    bummer mate, yeah when it comes to owning bmw's it pays to know a good specialist
    everyone else is a hamfisted idiot when it comes to these cars, by default. still i'll say it once i'll say it again the majority of automotive mechanics in the cities in australia are the bottom of the food chain as far as mechanics and tradies go. there is a specialist euro mechanic down at nerang on the gold coast, been recommended to me by a government Occupational workplace health and safety dude who looks after audits of crane rego's and inspections. who also happens to be a BMW enthusiast and has owned the both the same models as I currently have which is always an interesting conversation. my friend used him as well, honest bloke and honest prices. which is why he is constantly busy he is very much in demand. always has work on. not some dick that has no work on and tries to rort people in order to make up for the fact he has no work most of the time.
  1. Replacing 540i fuel pipes
    By euaniebabs in forum 5 Series BMW
    Last Post: 07-10-2007, 10:03 AM
  2. fuel pipes
    By Fraz06 in forum 5 Series BMW
    Last Post: 03-11-2007, 02:55 PM
  3. 3" pipes, etc.
    By hoser in forum 5 Series BMW
    Last Post: 02-01-2007, 04:39 AM
  4. exhaust pipes bracket
    By fsteyer in forum 5 Series BMW
    Last Post: 05-19-2006, 07:18 AM
  5. V8 Smoking Tail pipes...
    Last Post: 03-05-2006, 04:12 AM
