Engine pipe hardware question that I've been trying to work it out for a while to no avail.
On my M30 the engine pipes have no sealing rings. The tops of the engine pipes -where they connect to the manifolds- are flared and these flares mate to machined surfaces on the manifold output flanges. There are 2 pairs of stainless studs in the manifolds that stick out a good 50mm to allow a bracket to go on each pipe which is then secured by a compression spring and nut on each side of it.
I guess the springs help to manage movement if the pipe is forced is forced yet always bring the surfaces back to square with the right pressure on them to reseal.
Some engine pipes I have seen have flexible joints in them also. I believe many other M30 engined e34s have seal rings instead of bare machined surfaces. Does nayone know why various cars are different?
Mine is RHD, but I believe this is not the only factor.
Many thanks,
Nick
000000====))====CATS=========RESONATOR===MUFFLER=
Here is the bit I am talking about, I expected it to have seal rings, not mate straight up bare and use a pair of springs to load the surfaces.
