Originally Posted by
trumpetr
Sounds like what you had,,,,was an Endoscopic Appendectomy,,,,,youre right,,,they do put in an inert gas in your abdomen,,,,(co2 and nitrogen),,,,that inflates the belly,,and makes it easier for the scope, to see what they are looking for,and the scope has the cutters to cut out the offending part,,and also has cautery,,,,to seal up any bleeding. The third hole,,is for a suction catheter,,,,to suck out the stuff they cut away,,,irrigate with saline,,,and then suck out all that, again and again,,,,then,,,they close you up. The glue,,,is really just superglue, or cyanoacrylate,,works well, for a skin glue, for small surgical wounds.
Still cant figure out why they shaved your butt,,,,unless you have a bad case of the 'gorilla ass',,,,then it needed shavin' anyway.
They usualy dont even shave,,for proceedures much anymore,,,,,as they found the risk for post op skin infections (MRSA),,is worse than the fear for introducing possible infection during a proceedure, if they dont shave the surrounding area. Usually, they just give you a "Betadine tan", then tear into ya.
Talk about 'more info than needed',,,ref: your package being spared.
At the risk of digress,,,,,,why the ass shave,,and not areas more closer to the surgical areas? Again. do you know people at this hospital you had the proceedure done? Dang,,,,thats gotta be itching pretty good by now.
Kind of like sitting on nettles.
