Results 1 to 10 of 10
Thread: Master cylinder replacement
    Default You don't even need a pressure bleeder and will arguably get
    better results with a correctly done 2 man bleed instead.... other than that nothing special in bleeding the system with abs. Make sure you bench bleed the master first before installing it.
    I plan to replace my master cylinder and brake booster in the ver near future. The booster doesnt need replacing, but im buying them as a unit. Does anyone have any tips on this procedure? What can i do to avoid filling the ABS unit with air? Is a pressure bleeder all i need?
    Jul 2004
    Bentley's manual says it should be done by "a professional".
    I mean - how come it says that?
    deleted air conditioning
    Hockinson, Washington
    Quote Originally Posted by Rustam
    I wonder why it says that.
    so retards dont drive with air in the system and kill someone?
    tempe
    how much are stoptechs for the e34?
  1. E34 540i master cylinder replacement
    By charlie in forum 5 Series BMW
    Last Post: 08-02-2010, 08:38 AM
  2. Clutch Master Cylinder Replacement.
    By boardburton in forum 5 Series BMW
    Last Post: 11-30-2006, 04:33 PM
  3. Master Cylinder Help
    Last Post: 07-04-2006, 10:20 PM
  4. master cylinder gone bad?
    By panzershreck in forum 5 Series BMW
    Last Post: 08-19-2005, 09:44 PM
  5. 535 master cylinder
    By caster in forum 5 Series BMW
    Last Post: 10-08-2004, 07:45 AM
