Results 1 to 10 of 10
Thread: Master cylinder replacement
    Hockinson, Washington
    Default Master cylinder replacement
    I plan to replace my master cylinder and brake booster in the ver near future. The booster doesnt need replacing, but im buying them as a unit. Does anyone have any tips on this procedure? What can i do to avoid filling the ABS unit with air? Is a pressure bleeder all i need?
    Bump
    USA
    are you upgrading the brakes too?
    Quote Originally Posted by BillionPa
    No, but i will probably repalce the brake lines.
    USA
    get stoptech ones, they are very nice.
    and use good brake fluid obviously during the whole thing.
    the stoppers that come with the stoptech kit may also be able to keep air out of the abs unit, but vacuum bleeding with lots of extra fluid will also keep it out.
    Default You don't even need a pressure bleeder and will arguably get
    better results with a correctly done 2 man bleed instead.... other than that nothing special in bleeding the system with abs. Make sure you bench bleed the master first before installing it.
    Jul 2004
    Bentley's manual says it should be done by "a professional".
    I mean - how come it says that?
    deleted air conditioning
    Quote Originally Posted by Rustam
    I wonder why it says that.
    so retards dont drive with air in the system and kill someone?
    tempe
    how much are stoptechs for the e34?
  1. E34 540i master cylinder replacement
    By charlie in forum 5 Series BMW
    Last Post: 08-02-2010, 08:38 AM
  2. Clutch Master Cylinder Replacement.
    By boardburton in forum 5 Series BMW
    Last Post: 11-30-2006, 04:33 PM
  3. Master Cylinder Help
    Last Post: 07-04-2006, 10:20 PM
  4. master cylinder gone bad?
    By panzershreck in forum 5 Series BMW
    Last Post: 08-19-2005, 09:44 PM
  5. 535 master cylinder
    By caster in forum 5 Series BMW
    Last Post: 10-08-2004, 07:45 AM
