Hmm Im kinda not understanding what you mean.
Take a mulitmeter and measure both wires against ground or the negative battery pole, if you are gettin +12v (light must be turned on) then you have the wire that carrys the postive signal. You could also "ohm" it and when you get 0 ohms you have the wire that is carrying ground/negative.
